Swanc02's avatar
Swanc02
Follower
Dec 09, 2018
with an N900 adapter like NETGEAR WNDA4100 for maximum performance
 In the documentation for this gateway it says,  “use with an N900 adapter like NETGEAR WNDA4100 for maximum performance”.  My question:  Is that because it is not dual band? Can you convert it to du...
  • Blanca_O's avatar
    Dec 16, 2018
    Hi Swanc02
    Welcome to NETGEAR Community!
    WNDA4100 is a dual band WiFi adapter. This requires a dual band router for it to detect 2.4GHz and 5GHz network. If your existing router is not dual band then it will simply detect 1 frequency which is the 2.4GHz.
    This is also designed for PCs or laptops. It will not work for PS4.
    Blanca
    Community Team
