Ashwin5171
Oct 17, 2015Aspirant
WN111v2 Usb adapter | Windows 7 pro problems
Hello my name is Ashwin. I have had a WN111v2 for a long time and it has served me faithfully. Unfortunatly when I was running a deepscan to find viruses my father walked into the room and hit the ma...
JamesGL
Oct 20, 2015NETGEAR Employee Retired
Hi Ashwin5171,
Welcome to Community!
I would suggest uninstalling and reinstalling the adapter. You can go to support.netgear.com for the driver of the your adapter.
JamesGL
Community Team
Ashwin5171
Oct 25, 2015Aspirant
Hey James I already tried that, but it still did not work anyother suggestions?
- JamesGLOct 27, 2015NETGEAR Employee Retired
You may try to install it on a different computer to isolate if the problem is with the adapter.
JamesGL
Community Team
