tag49
Aug 14, 2016Aspirant
WNA1100 2.0.0.5 installation : intrusion detection
Hello,
I have recently download and install le new version of my WNA1100. During the process, I choosed 'repair / modify', and my security system (bitdefender) alerts me on malicious detection.
Here is the screen :
Any info ?
Thanks,
- JamesGLNETGEAR Employee Retired
Hi tag49,
Uninstall the adapter's driver completely and reinstall it using the latest driver instead of doing a repair.
JamesGL
Community Team
Hi tag49,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
- tag49Aspirant
Hello,
After remove the driver / installation, clean the registery and reboot the computer, the problem is still present :-( .
The driver and the wifi key work well, but I have this message on each installation.
Tag49
Hi tag49,
Can you try to use a different computer? or disable the antivirus first when installing the adapter and enable it after the installation.
JamesGL
Community Team
