cbastin
May 27, 2017Aspirant
WNA1100 arthurx.sys update
Hello, My WNA 1100 N150 adaptor has an issue where it will occasionally cut out and cause my PC to blue-screen. It points to one of the drivers, arthurx.sys, as the cause. Looking around, th...
JamesGL
May 29, 2017NETGEAR Employee Retired
Hi cbastin,
Uninstall it under the programs. Remove the folder of NETGEAR in the program files in C drive. When reinstalling, use the standalone driver.
- JamesGLJun 04, 2017NETGEAR Employee Retired
Hi cbastin,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- cbastinJun 06, 2017Aspirant
Hi, Sorry for the delayed response.
I unplugged the adapter, removed all Netgear drivers and files from my computer. Began the installation, but then it prompted me to insert the Wireless Adapter which installed its own driver before the installation could be completed. The driver settings say it's 2.0.0.57 instead of the 2.2.0.1 of the installer.
Due to this, could I simply ask for the updated version of arthurx.sys or any other method to manually upgrade the driver?
- JamesGLJun 12, 2017NETGEAR Employee Retired
Hi cbastin,
Please try this.
https://kb.netgear.com/30146/How-to-manually-update-the-driver-of-NETGEAR-Adapters
