nksaini
Jan 06, 2019Aspirant
WNA1100 N150 disconnect at random interval
My WNA1100 USB adapter disconnect at random -- sometimes every few minutes and sometimes, say, once a day. I am using this on Windows 7 Desktop PC and have the latest software for this device. The pr...
- Jan 10, 2019
Hi nksaini
Welcome to NETGEAR Community!
Please follow the steps below:
- Open Device Manager > Network Adapters
- Select NETGEAR WNA1100
- Right-click then select Properties
- Under Power Management Tab, disable "Allow the Computer to turn off this device..."
Here is the link for the latest driver WNA1100 Software Version 2.2.0.1
Blanca
Community Team
Blanca_O
Jan 10, 2019NETGEAR Employee Retired
Hi nksaini
Blanca
Community Team
- nksainiJan 10, 2019AspirantHi Blanca_O,
I will follow the steps and see if this resolves the issue. I will post the result here after 2-3 days.
Thanks,
nksaini - Blanca_OJan 13, 2019NETGEAR Employee Retired
- nksainiJan 13, 2019Aspirant
Hi Blanca_O,
It appears that after following the steps suggested by you, i.e. after disabling "Allow the Computer to turn off this device..." in Properties dialogue box of my Netgear WNA1100 Network Adapter, the problem of disconnection is solved. In the past 2-3 days I have not experienced disconnection of the adapter.
Thaks for your help.
