WJvanEden
Nov 13, 2015Star
WNA3100 constantly disconnecting on Windows 10
Hello, I own two WNA3100: http://support.netgear.com/product/WNA3100 wifi adapters, one for a Windows 10 machine, the other for a Windows 7 machine. The one I'm using for Windows 7 works fine and has...
- AnonymousJan 14, 2017
i found a solution that worked for me:
https://community.netgear.com/t5/WiFi-Adapters/A6200-Disconnecting-on-Windows-10/td-p/981072
Step 1:Go to "Control Panel > All Control Panel Items > Power Options > Change Plan Settings > Change Advanced Power Settings".Step 2:Expand "Wireless Adaptor Settings > Power Saving Mode" and make sure it is set to "Maximum Performance".Step 3:Expand "USB Settings > USB Selective Suspend Settings" and change Setting to "Disabled".
David2001
Dec 11, 2015Aspirant
I've just starting getting this problem with the WNDA3100v2 right after Win 10 had resarted after an automatic update. Reset the router, no luck. Downloaded the Win 10 driver (no genie), uninstalled the current driver (same version as the downloaded one), rebooted the system and installed the downloaded one. Installation stalled with a pop up error x103 titled SupTools so no functioning wifi.
David
David2001
Dec 19, 2015Aspirant
Installed the Genie version and didn't get the x103 error but still have the drop out problem. I've also tried the A6100 adapter and get exactly the same dropout problem so it's not just this adapter. A bit frustrating to say the least!
David
