WJvanEden
Nov 13, 2015Star
WNA3100 constantly disconnecting on Windows 10
Hello, I own two WNA3100: http://support.netgear.com/product/WNA3100 wifi adapters, one for a Windows 10 machine, the other for a Windows 7 machine. The one I'm using for Windows 7 works fine and has...
- AnonymousJan 14, 2017
i found a solution that worked for me:
https://community.netgear.com/t5/WiFi-Adapters/A6200-Disconnecting-on-Windows-10/td-p/981072
Step 1:Go to "Control Panel > All Control Panel Items > Power Options > Change Plan Settings > Change Advanced Power Settings".Step 2:Expand "Wireless Adaptor Settings > Power Saving Mode" and make sure it is set to "Maximum Performance".Step 3:Expand "USB Settings > USB Selective Suspend Settings" and change Setting to "Disabled".
whatever123
Jun 04, 2016Aspirant
well i have the same one with the same problems for months i been having problems tweaking adjusting and nothing keep on disconnecting sad enough its not the atenna part its the cable if you replace the cable part go to any computer store and get a USB extention you will see your problem may be solve on my end i have no problems, sad enough all this big company sub let thing to complete there system incuding cable connection and so on and they are made badly, ya company's is not like they use to anymore pryed well thank you netgear for wasting many month's of my time to fix it on my own
