WJvanEden
Nov 13, 2015Star
WNA3100 constantly disconnecting on Windows 10
Hello, I own two WNA3100: http://support.netgear.com/product/WNA3100 wifi adapters, one for a Windows 10 machine, the other for a Windows 7 machine. The one I'm using for Windows 7 works fine and has...
- AnonymousJan 14, 2017
i found a solution that worked for me:
https://community.netgear.com/t5/WiFi-Adapters/A6200-Disconnecting-on-Windows-10/td-p/981072
Step 1:Go to "Control Panel > All Control Panel Items > Power Options > Change Plan Settings > Change Advanced Power Settings".Step 2:Expand "Wireless Adaptor Settings > Power Saving Mode" and make sure it is set to "Maximum Performance".Step 3:Expand "USB Settings > USB Selective Suspend Settings" and change Setting to "Disabled".
joey3406
Jul 25, 2017Aspirant
Hey guys, the "solution" posted for this topic actually does not solve my problem. I just thought I'd let you know that when I plugged my WNDA into a 3.0 usb slot, it fixed this problem for me. I no longer disconnect.
There ya go,
Joe
- PhotographerKenJul 25, 2017Tutor
I was plugged into a USB 3, although it should not matter as the adapter is USB 2.
I fixed the problem as well, I threw away the worthless Netgear adapter and replaced it with another brand that works flawlessly out of the box. This was the second major issue I have had with a Netgear product that Netgear had no fix for, nor would they replace. I am not mad, I have just learned my lesson. I will never buy another Netgear product again.
