WJvanEden's avatar
Nov 13, 2015
WNA3100 constantly disconnecting on Windows 10
Hello, I own two WNA3100: http://support.netgear.com/product/WNA3100 wifi adapters, one for a Windows 10 machine, the other for a Windows 7 machine. The one I'm using for Windows 7 works fine and has...
  • Anonymous's avatar
    Anonymous
    Jan 14, 2017
    i found a solution that worked for me:
    https://community.netgear.com/t5/WiFi-Adapters/A6200-Disconnecting-on-Windows-10/td-p/981072
    Step 1:Go to "Control Panel > All Control Panel Items > Power Options > Change Plan Settings > Change Advanced Power Settings".
    Step 2:Expand "Wireless Adaptor Settings > Power Saving Mode" and make sure it is set to "Maximum Performance".
    Step 3:Expand "USB Settings > USB Selective Suspend Settings" and change Setting to "Disabled".
