WJvanEden
Nov 13, 2015Star
WNA3100 constantly disconnecting on Windows 10
Hello, I own two WNA3100: http://support.netgear.com/product/WNA3100 wifi adapters, one for a Windows 10 machine, the other for a Windows 7 machine. The one I'm using for Windows 7 works fine and has...
- AnonymousJan 14, 2017
i found a solution that worked for me:
https://community.netgear.com/t5/WiFi-Adapters/A6200-Disconnecting-on-Windows-10/td-p/981072
Step 1:Go to "Control Panel > All Control Panel Items > Power Options > Change Plan Settings > Change Advanced Power Settings".Step 2:Expand "Wireless Adaptor Settings > Power Saving Mode" and make sure it is set to "Maximum Performance".Step 3:Expand "USB Settings > USB Selective Suspend Settings" and change Setting to "Disabled".
PhotographerKen
Aug 13, 2017Tutor
What did you figure out??? Did you resolve the problem? If so, how?
You can see in a previous post, I resolved the problem and have not had a single issue since.
Earthen
Aug 13, 2017Initiate
Like I said I tried everything on this forum including hooking it up to a USB 3.0 and it still disconnected until I unplug my external hard drive
