sescabit
Feb 10, 2016Aspirant
WNA3100 wifisvc.exe keeps stopping
I have a Windows 7 Pro PC (Acer) where it keeps falling off the network with 'wifisvc.exe has stopped' in the event log. Any idea how I can resolve this? [I'm unable to enter anything in the Model box...
sescabit
Feb 14, 2016Aspirant
Yes, I'd already decided to try this. I'll thoroughly clean out the existing installation then try a fresh install. No guarantee that it will resolve the problem, but it's pretty much my only option.
What I don't understand is why the picture on the download page shows the older, bigger WNA1100 adapter rather than the stubby N300 adapter. Is the software the same?
JamesGL
Feb 22, 2016NETGEAR Employee Retired
Hi sescabit,
They have the same design but the page is for WNA3100.
- sescabitFeb 22, 2016Aspirant
Thanks James, but I decided to use the software for the smaller WNA3100M, which has a different (lower) version number. I also discovered that I had two separate versions of the software installed, so I removed everything before reinstalling. Fingers crossed that it will be stable from now on. Thanks for your help.
David
- JamesGLFeb 23, 2016NETGEAR Employee Retired
Hi sescabit,
Feel free to provide us feedback.
- sescabitMar 09, 2016Aspirant
Hi James
I reinstalled the adapter (WNA3100M) using the latest version of the software, but the problem continues. Here's the Event Log entries from a wireless adapter failure last week. (Windows 7 Pro)
Faulting application name: WifiSvc.exe, version: 2.1.0.24, time stamp: 0x53cdc9f5
Faulting module name: WifiLib.dll, version: 2.1.1.20, time stamp: 0x55a6273a
Exception code: 0xc0000005
Fault offset: 0x00003486
Faulting process id: 0x9e0
Faulting application start time: 0x01d1752c10740b9a
Faulting application path: C:\Program Files (x86)\NETGEAR\WNA3100M\WifiSvc.exe
Faulting module path: C:\Program Files (x86)\NETGEAR\WNA3100M\WifiLib.dll
Report Id: a8b7e068-e12d-11e5-9411-c03fd5545539Faulting application name: WifiSvc.exe, version: 2.1.0.24, time stamp: 0x53cdc9f5
Faulting process id: 0x3100
Faulting application start time: 0x01d1753a6e15b781
Report Id: 929e7c40-e135-11e5-9411-c03fd5545539Regards,
David
