technotsavvy
Aug 05, 2015Follower
WNCE 2001 vs WNCE 3001
Hi--I've used a NETGEAR WNCE2001 for years adapting my workhorse HP CM1312 mfp color laser printer to enable it to print wirelessly. It now seems to have puckered out...green light on for a minute t...
JamesGL
Aug 14, 2015NETGEAR Employee Retired
Hi technotsavvy,
The advantage of purchasing WNCE3001 is that it is dual band which can connect to higher frequency (5Ghz) with less interference although just for shorter range compared to 2.4Ghz and the WNCE2001 as well is already End of Life which means service is no longer available and no more updates.
JamesGL
Community Team
