crossbeaux
Jun 25, 2016Aspirant
WNCE2001 power led blinking green and no connection
There was another topic with this same name, but it is closed. I have the same problem, and none of the solutions listed there worked for me. The power light continues to flash green and the unit d...
JamesGL
Jun 29, 2016NETGEAR Employee Retired
Hi Crossbeaux,
Please check this link as this might help you.
- crossbeauxJun 29, 2016Aspirant
That's the link that I did check first. Tried everything suggested and nothing works. Again, this thing is a POS.
- JamesGLJun 30, 2016NETGEAR Employee Retired
Hi Crossbeaux,
The only way to recover the firmware is through TFTP. If it did not work for you, which means the adapter is no longer working.
- crossbeauxJun 30, 2016Aspirant
Yes, I tried tftp and it did not work. It attempted to push data but timed out. Like I said, POS.
