spitlist
Feb 04, 2017Aspirant
WNCE2001 Power LED blinks green and I cannot set it up
I see that there is already a thread on the subject and there are several links that purport to fix the problem. However these links are very long and end up being truncated so when I click on them, I getthe NETGEAR support page asking for the model instead of the actual link.
Can someone tell me how to fix this problem?
- JamesGLNETGEAR Employee Retired
Hi spitlist,
1. Can you still access the UI of the adapter?
2. Are you getting a valid IP from the device? Can you ping the IP address of the adapter?
- spitlistAspirant
I have no idea what you are asking? What is "UI"?
The device doesn't have an IP address. It is a unit that is supposed to intercept a WIFI signal and convert it to a wired connection via an RJ47 port.
- spitlistAspirant
Make that RJ-45 (fat fingers)
Hi spitlist,
1. Reset the adapter.
2. You should still be getting an IP address from the adapter even if it is not connected to the router.
- spitlistAspirant
WHat adapter?
