boourns
Jan 05, 2016Aspirant
WNDA3100v3 on Windows 10 Not Enabled
I recently upgraded my OS from Windows 7 to 10. My WNDA3100v3 wifi adapter worked perfectly with 7, but has had issues with 10. After not being able to connect, I uninstalled my driver and reinstalled the Netgear driver file: "WNDA3011v3_v1.0.0.10" but cannot connect to networks. The computer recognizes the wifi adapter in my usb drive, the wifi adapter has it's power light on, but I cannot enable it in Network Connections. When I try to do that, it says it is enabling, eventually says it is enabled, but when I return to Network Connections, it continues to say it is disabled.
Do you have any suggestions for next steps with troubleshooting?
Thanks!
- JamesGLNETGEAR Employee Retired
Hi boourns,
Uninstall the driver of the adapter. Reinstall it using the standalone driver. Disable antivirus or firewall for the mean time while installing the adapter.
