iHate2BeThatGuy
Jul 19, 2016Follower
WNDA4100 Mac Installation
Hey how do i install my WNDA4100 on the latest Mac OS X? I have clicked index.htm but still cannot find the installation wizard.
- zmayoAspirant
I have the same issue. I suspect that they're not compatible. I have had a lot of trouble trying to find a similar device compatible with Mac. I'm very disappointed that Netgear does not appear to have a device that will work with a Mac. I don't understand why it includes instructions on the CD, even though clicking an htm file to install doesn't make any sense.
- JamesGLNETGEAR Employee Retired
Hi All,
None of our USB adapters will work with MAC but you may try checking other adapters like WNCE4004 or WNCE3001. These are wireless adapters using the LAN port not the USB.
JamesGL
Community Team
Hi All,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
