DavidMZ
Jul 29, 2016Aspirant
2500 Extender will not connect
My 2500 extender suddenly stopped working today and would not reconnect. With the guidance of a Verizon tech support person, I did power recyclings and a factory reset on both it and my Verizon Gatew...
DarrenM
Aug 01, 2016Sr. NETGEAR Moderator
Hello DavidMZ
Make sure your router is using WPA2 security type you may also want to change the wireless channel on the router. You could also try to use WPS to attach the extender.
DarrenM
- DavidMZAug 01, 2016Aspirant
Thanks Darren, I tried the first and third and will try the second.
