romain3369's avatar
romain3369
Follower
Dec 28, 2016
29% power with N300, would it be better with AC1200 ?
Hi community !
I have installed a N300 WiFi extender but the connection is bad. I have only 29% signal power between my router and my extender !
If I replace the N300 for a AC1200, would I have a better connection between my router and my extender ?
I can't place the N300 close to the router because it's a perfect place regarding the position of the device I want to connect !
Thanks for your answers :)
Romain
PS : Sorry for my bad English, I'm a french Netgear user ;)
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello romain3369
    You may want to try and change your wireless channel on your router it should be in the wireless settings to see if you can get a better connection.
    DarrenM
