romain3369
Dec 28, 2016Follower
29% power with N300, would it be better with AC1200 ?
Hi community !
I have installed a N300 WiFi extender but the connection is bad. I have only 29% signal power between my router and my extender !
If I replace the N300 for a AC1200, would I have a better connection between my router and my extender ?
I can't place the N300 close to the router because it's a perfect place regarding the position of the device I want to connect !
Thanks for your answers :)
Romain
PS : Sorry for my bad English, I'm a french Netgear user ;)
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello romain3369
You may want to try and change your wireless channel on your router it should be in the wireless settings to see if you can get a better connection.
DarrenM
