MikeStahl
Mar 28, 2012Aspirant
5GHz doesn't light but shows on devices
My router from what I read doesn't have 5GHz only 2.4. 5 GHz light not on extender but the 5GHz wifi name along with 2.4 show up on my IPAD. (not IPHONE). What's going on? The 5 is stronger signal. ...
fedup2012
Nov 10, 2012Aspirant
I have same problem. The WN2500RP just wont connect to router at 5ghz. Devices can see and connect 5GHZ band on WN2500RP but because WN2500RP cannot connect to router at 5ghz, the devices have not LAN/Internet access.
The led for 5ghz on the WN2500RP does not illuminate- although on cycling off/on it does display on diagnostic start up.
Now on second (replacement unit).
As is other post I think its a dud.
