billybobcory
May 16, 2015Aspirant
5GHz Light stays "off" EX6200 Why?
I can't get the 5Ghz EX6200 light to stay on solid. I spent an hour on the phone with a Netgear Technician. He told me that unless I have a device that uses 5GHz the Extender 5Hz will not light up. H...
iquiax
Dec 04, 2015Initiate
had the same problem when I 1st tried the standard installation
what you need to do
1. log into the netgear set up page
go to the 5ghz wifi setup, under channel choose 44
2. log into your router set up page
go to the5ghz wifi setup, under channel also choose 44
then the 5ghz connection led should light up on your extender right away.
hope this helps
