fredduke
Nov 15, 2016Aspirant
AC1200 Netgear to netgear Nighthawk Ex7300
I have the AC1200 Netgear installed and I want to replace it with the Nighthawk do I have to delete the AC1200 before I install the Nighthawk?
Hello fredduke
If you are just replacing it then no your just need to setup the new Nighthawk Ex7300.
DarrenM
- DarrenMSr. NETGEAR Moderator
Hello fredduke
You would have to factory reset the extender if you are adding a new router.
DarrenM
- freddukeAspirant
Maybe I did not clearly ask the question, I want to replace the AC1200 with the Nighthawk. I am a novice at this computer stuff so I am not sure what you mean by doing a reset. Could please explain what a reset is. Thanks
Hello fredduke
DarrenM
