Leehan70
Sep 08, 2018Follower
AC1200 Wifi extender EX6110
Hi need help cant connect any device to my EX6110 Wifi extender, when prompted to enter the network security key i just get a message saying network security key is wrong. I know i am entering the co...
Sep 08, 2018Guru - Experienced User
Did you try re-entering the passphrase in the extender's web ui?
It is possible to access the web admin page from the router network, or by connecting a PC to the extender ethernet. Though you could alternatively do a factory reset on the extender.
- barjobeeSep 14, 2018Aspirant
my provider replaced my router with a new one . I tried to connect with the extender but no luck ... what do I need to do? I'm not real computer savvy ...
I've tried to factory reset and tried the WOS several times no luck
excuse me the WPS...
- StephenBSep 15, 2018Guru - Experienced User
barjobee wrote:
I've tried to factory reset and tried the WPS several times no luck
Then try again, and set up the extender w/o using WPS. See Connect with the NETGEAR Installation Assistant on page 11 here: http://www.downloads.netgear.com/files/GDC/EX6110/EX6110_UM_EN.pdf
