KarlDM007
May 20, 2018Follower
AC1200 Wifi Range Extender Problem
I can only get WiFi reception half-way to the other side of the house with my NETGEAR17 Nighthawk DST Router R7300DST & DST Adapter DST6501 (NETGEAR17_EXT). What is next - run a landline ethernet from router to the other room on other side of the house?
Tks,
KarlDM007
1 Reply
- DarrenMSr. NETGEAR Moderator
You may need another DST adapter for the other side of your home to get the coverage that you are wanting.
DarrenM
