PeterJA
May 16, 2017Aspirant
AC1900 D7000 wifi loss using TP Link extenders
Hi, I have successfully installed the D7000 and appear to have no problem with internet connection. However, I have connected it to TP link extender network and the wifi works and then unexpectedl...
DarrenM
May 19, 2017Sr. NETGEAR Moderator
Hello PeterJa
Have you tried to reserve the IP address of the extender? also have you tried a different ethernet cord?
DarrenM
- PeterJAMay 20, 2017Aspirant
Many thanks for your response. Have tried a Cat 6 cable with nochange. Not sure how to reserve an IP address.
It appears that the Netgear router regularly does not issue out IP addresses to devices. Is that fixable on the router or do I need to bin it ?
- GearNetRouterMay 24, 2017Virtuoso
The manual gives an excellent narrative on how to reserve an IP.
- DarrenMMay 24, 2017Sr. NETGEAR Moderator
Hello Peter
Here is a Kb on how to do this.
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
DarrenM
