sengeb52
Feb 04, 2026Aspirant
AC1900 Wifi Extender help
I have tried many, many factory resets, I have unplugged and plugged the extender, I have moved outlets, I have moved rooms with the extender and I cannot fix my issue.
If I plug in the extender and try a WPS set up, the power and WPS LEDs turn green, but the router and client do not.
If I plug in the extender and look for NETGEAR_EXT it does not show up on my laptop, nor my phone.
If I plug in the extender and try using the Nighthawk app, I get the same "Unable to join the network error." I have clicked and tried all of the solutions in "still having issues" section.
I cannot connect my laptop directly to the router, because it only has a USB-C port
I have been at this for over 2 hours at this point. Do I just have a bad extender or what am I missing?
Any progress on this?
If the power button is flashing amber, its failing the bootup process. So either a hardware failure or a firmware failure.
You can try recovering it with tftp. This is for router but it works the same on extenders. There's also videos online.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
make sure tftp is enabled on your device.
https://www.thewindowsclub.com/enable-tftp-windows-10
What router are you connecting it to?
It wouldn't be the first time that a factory reset hasn't worked. But I still have to ask, are you pushing and holding reset for 7-15 seconds while powered on? I fequently see people just click the button.
- sengeb52Aspirant
I am trying to connect it to my Nighthawk XR500. I have rebooted this router through the app, unplugged it, plugged it back in and turned off the wifi with the manual button on the router and turned it back on. I have tried having the router connected locally and setting up the extender and having it set to anywhere access as well. Still no luck.
I am pushing the reset while it is plugged in for up to 40 seconds (saw someone wrote that cured their problem on this site). The power button flashes amber.
- sengeb52Aspirant
Forgot to add: EX6400v3
