kamkam123's avatar
kamkam123
AC1900 WiFi Range Extender 2.4g work but 5g says no connection
So, i have the extender setup and 2.4g is connecting to the internet but 5g says no connection. I was on the latest firmware 1.0.1.112 but reverted back to an older version with no success.  Any ideas why I can use 2.4 but not 5g???  Next steps?
  • plemans's avatar
    Jun 13, 2024
    that "no connection" you see on the status page? That means there isn't a device (phone/tablet, etc) connected to the extenders 5ghz.
  • schumaku's avatar
    schumaku
    What is the ide reverting to an older firmware version please? Re-introducing security vulnerabilities or loosing the ability to use the simple basic https support added on .112?
    Probably the 5 GHz band was not configured properly, or the existing WiFi router handling the 5 GHz band config was changed?
    kamkam123 wrote:
    Next steps?
    As usual here, factory reset the EX7000 to the default config, and reconfigure the unknown to us connections to the primary Wi-Fi router from scratch again. Consult the fine documentation FMI.
    • plemans's avatar
      What router do you have?
      What method of setup did you use?
      • kamkam123's avatar
        kamkam123
        AC1900 EX7000
        I used the Netgear sotware to setup the extender and did a smart setup
      kamkam123
      I have done the factory reset and updated back to the latest firmware, but it still only shows 2.4 as connected to the internet and not 5g
