ml49's avatar
ml49
AC750 (EX2800) WiFi Range can't be reset to establish connection with new network
I've used this AC750 (EX2800) for an existing home wifi net work for a couple of months and then upgraded the network speed with Fios. Now I have the fastest Fios router. However I was not able to connect AC750 to the new router. I've tried RESET the extender and connect it multiple times...
  • Using WPS didn't work - WPS LED light only blinks, touch the button again within 2 mins and it still blinks, never stays one;
  • Connecting to NETGEAR_EXT and visiting mywifiext.com or mywifiext.local (I'm on Mac and iPhone) didn't work either - the browser simply can't find the page.
So now I'm stuck. Both methods are not working. Any solution?
I have to say NETGEAR's free trouble shooting within 90 days does not make sense in this case. I didn't need any help when setting it up the first time, sure, but who reset their network frequently? If the extender can't be reseted it'll become a piece of garbage.
  • plemans's avatar
    1. what router are you trying to connect it to?
    2. what firmware is on your extender?
    3. when you factory resets, did you push and hold resets for 7-15 seconds while the extender was powered on?
    4. what error do you get when you try to connect to the netgear_ext network? Did you try different pc/laptop/devices? Or different web browsers?
    • ml49's avatar
      ml49
      Problem solved this morning! I received the latest Verizon Router - the one that looks like a tower. I read online that on the previous rounder version Fios router there is a 'WPS' button, so I looked at the back of the new router and found a button with a link icon on it. I hold that 'link' button on the router until it starts to blink and then press the WPS button on the extender, and the connection was established right away.
      Previously, I did not know where to look for firmware on the extender since I couldn't connect to it. Pretty sure I've hold the RESET button for a long time. It restarted from red. I've used my iphone connecting to NETGEAR_EXT and try to manually type in the setting in the default browser, it says Safari can't find the page. Same thing on my iMac. I have no PC here.
      Anyway, thanks for trying to help.
