amitylyn
Dec 17, 2016Aspirant
AC750 EX6100 - New Extender Setup
Hi. Not sure what I'm doing wrong, but my network names don't come up as extensions of my existing WiFi network name; both come up as EX6100_NETGEAR_2GEXT and 5GEXT. Can anyone help? Thanks.
- Jan 03, 2017
Hello amitylyn
Yes you will have to log into the router by going to www.mywifiext.net and renaming the extender if you want a different SSID.
DarrenM
RMinNJ
Dec 27, 2016Luminary
Oh.. I have not used WPS... maybe thats why the names are not those of your existing network.
I would go to the admin status page ( I used a network cable plugged in from my laptop) ...make sure the extender has connected to your network. Then name the 2.4 and 5 network what you like.
FWIW: I used one of the netgear "fastlane" settings where it connected to my router at 5GHz (866mbps) ...then it broadcast only 2.4G for the
extended network upstairs). So I only have t one extra SSID I called it myssid_5G_2Gext.
DarrenM
Jan 03, 2017Sr. NETGEAR Moderator
Hello amitylyn
DarrenM
- amitylynJan 07, 2017Aspirant
That worked, thanks! I just got hung up on the fact that they weren't automagically named, like the instructions said.
Thanks again!
