goldend
Mar 25, 2017Aspirant
AC750 (EX6100?) works fine for a while then cannot be accessed without a restart
I have my unit set up as an extender and when I first turn it on and it finishes booting, it runs fine, within 24 hours it drops the connection to my wireless camera and i cannot connect to it with my iPhone. a power cycle gets it going again.
- DarrenMSr. NETGEAR Moderator
Hello Goldend
have you updated to the latest firmware? also you may want to change the wireless channel on your router.
DarrenM
- goldendAspirant
I have the current firmware. i have not tried changing channels, but I do not believe that is the problem. When it 'goes dark', I cannot connect to it with my iPhone or iPad using mywifiext. The only way to revive it is to power off and power on. I would love to set up an automatic power cycle, but do not see that as an option.
- goldendAspirant
Is my device defective? This failure occurs between 12 and 48 hours of up time.
Hello goldend
Its hard to tell but if your device is still under warranty I suggest contacting support if you think it is a hardware issue.
https://www.netgear.com/support/contact.aspx
DarrenM
