TVincent's avatar
TVincent
AC750 Model EX3700 keeps asking me for sign-in
Why is my extender suddenly asking me to sign in? Recent change after years of use and means I have lost e.g. Amazon access etc on TV and mobile phone. Why has this suddenly started to happen? How do I turn off?
  • plemans's avatar
    Did you set it up using the push button WPS option?
    If so, factory reset the extender  and set it up using the installation assistant.
    To factory reset, push and hold the reset button for 7-15 seconds while powered on.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
    • TVincent's avatar
      TVincent
      Hi, I didn't use WPS to set up but will try a re-set. Thanks
      • plemans's avatar
        If that doesn't work what router are you connecting it to?
        What firmware is on the extender?
