Kopite
Dec 07, 2015Follower
AC750 set up
Hi, when setting up my extender it doesnt come up with my existing network name but a pre-populated ones - jpm2_2GEXT and jpm2_5GEXT and i can't edit these.
Any ideas what to do?
Cheers
John
1 Reply
- nhannNETGEAR Employee Retired
Hi Kopite,
Which AC750 Extender do you have? For example: EX3700, EX6100, EX3920
Connect to your extender network, go to Settings, WiFi, then change your network's SSID.
Or Power on your extender, the press the factory reset button for at least 7 seconds. Release the button and the extender will restart.
On your computer, connect to NETGEAR_EXT and go to mywifiext.net to complete the setup. During the setup process you can name your Extender's network.
For more info, please download the user manual here:
http://www.downloads.netgear.com/files/GDC/EX3700/EX3700_UM_8may2015.pdf
http://www.downloads.netgear.com/files/GDC/EX6100/EX6100_UM_27Oct2015.pdf
http://www.downloads.netgear.com/files/GDC/EX3920/EX3920_UM_28may2015.pdf
