mousecar86's avatar
mousecar86
Follower
Feb 19, 2017
AC750 Wifi Extender Help Please
Do I have to reconfigure this exenter everytime I move it around the house? Because I moved this extender to a new location and I had to the whole process of configuring the extender. I wanted to contact support but my surprise Netgear only has a complimentary support that expired last month..boooo... Because if I have to do that it would be really annoying to find a good wifi spot to put the extener permanently.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello mousecar86
    You should not have to do the setup again unless you change the router that you are using.
    DarrenM
