jermlh's avatar
jermlh
Access Point to Arris Router
I have AT&T fiber with a Arris BGW 210-7000 Router. I have been using my EX 7000 Range Extender as an acces point. I went away for a week and when I returned I could no longer get a connection using the range extender. I have tried everyhing but cannot get connection. Any suggestions on how to solve problem? Thanks.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Did you try to factory reset the extender by holding the reset button for 10+ seconds then setting up the extender again?
    DarrenM
  • Hi jermlh,
                   Did you performed network power cycle by rebooting your gateway and EX7000 in sequence?
                   What error message did you encounter while connecting devices to the extender?
    • jermlh's avatar
      jermlh
      Thanks for the suggestion. I tried it but wa unsuccessful.
    • jermlh's avatar
      jermlh
      Thanks for the suggestion. I tried your suggestion but still could not get internet although i had a "connection."
      • jvasanth1984's avatar
        jvasanth1984
        Virtuoso
        Hi jermlh,
                       Can you check if you bypass the extender which is AP mode and internet works through the same ethernet cord which was providing connection to it?
