crispy3
Sep 27, 2018Guide
Address Reservation with EX7300 Mesh WiFi Extender
I'm using a Nighthawk R7500v2 and just added a EX7300 mesh extender. I need to have assigned/reserved IPs for specific devices that are now connecting to the extender rather than directly to the rou...
crispy3
Sep 27, 2018Guide
I did some more digging on this topic and found these bullet points in the product manual for the EX7300:
4. Select Settings > Connected Devices. The Connected Devices page displays the MAC addresses and virtual MAC addresses for computers and WiFi devices that are connected to the extender network.
5. On the router, add the extender’s virtual MAC address and all the virtual MAC addresses connected to the extender network to your router’s MAC filter table.
There are no "virtual MAC addresses" listed anywhere on the connected devices page. It only lists IP Address, Device Name, and MAC address, which is the original MAC address for the device, not an altered or "virtual" one.
- StephenBSep 27, 2018Guru - Experienced User
Note that if the extender is connected to the router network then it shouldn't be assigning any IP addresses. The DHCP messages are forwarded to your router, and it assigns the addresses.
The extender will assign IP addresses when it isn't connected to a router network. That's needed to allow extender setup.
Is the extender working properly (that is, can you reach the internet when you are connected to it)?
Assuming the devices connected to the extender can reach the internet...
You should be able connect the devices to the extender, and then see the virtual mac address in the router's attached devices list.
It is also possible to get them from a PC. With Windows you can ping the device, and then use arp -a. That will show you the full arp cache (including the device you just pinged).
Note that the router won't let you reserve the same IP address to two different mac addresses.
- crispy3Sep 27, 2018Guide
Unfortunately the 'Connected Devices' interface on the router does not list these devices, however they are connected to the extender and do have internet access. When I view the extender (mywifiext.local - which forwards me to the extender), it lists these devices but with their correct, non-"virtual" MAC addresses.
After pinging the devices and running arp -a, all devices connected to the extender have the same MAC address, which appears to be invalid. They are all listed as e:2:8e:98:96:6c, including the extender itself. So I'm still at a loss as to how to assign these devices IP addresses.
By the way this is the hardware and firmware:
Router - Nighthawk X4 R7500v2 -- V1.0.3.36
Extender - EX7300 -- V1.0.2.136
