sojourn_out's avatar
sojourn_out
Airbnb Wifi Extender Options (6,800 sq ft.)
Hello!
I am a property manager for a 6,800 sq. ft. Airbnb property.
I have been working with different wifi pods/extenders to help increase connectivity and speed for my guests.
These have not been working. I talked with my internet provider and they recommended I look into Orbi. I have never used a system like this before, but I am willing to try it.
I bought a Whole Home Wifi System, Tri-band Wifi. Comes with one router and two satellites. But now I need to know what is recommended if I was to buy multiple extenders, or satelittes.
I do need to buy more satellites.
Thanks!
  • plemans's avatar
    options that are compatible?
    RBS20
    RBW30
    RBS40
    RBS40V (with voice)
    RBS50
    RBS50Y (outdoor)
    All of them would work.
    Something to keep in mind though is the 50 series has a 1733mbps backhaul. The lower series (40 and under) use a slower 866mbps backhaul. So if you buy and use those and are daisy chaining, make sure they're at the end of the chain so they don't create a bottleneck.
    what I mean is go:
    rbr50----->rbs50------>rbs/rbs40 and under
    dont' go:
    rbr50---->rbs20------>rbs50
    The versions with the 866mbps backhaul still work great but its just something to keep in mind if you're daisy chaining satellites.
    • plemans's avatar
      And thats if you have the RBK53 kit. I was assuming that because you had it in the signature/device line.
      • sojourn_out's avatar
        sojourn_out
        Hello! We currently have one RBK23 router and two RBS20 satellites.
        These have worked for a while, but we would still get dead spots around the property.
        In this image it shows the property. We have 8 units total. I have the router (red spot) in Unit 1, and satellites (also red spots) in Unit 5&8.
