GilDawson's avatar
Aug 17, 2022
Another device on the network is using your computer's IP address; EX6100v2 culprit
We have a Netgear EX6100v2 Range Extender working with an Arris NVG443B  DSL modem/router.   About 15 devices connect via WiFi; no cables.   I configured the EX6100v2 to use one SSID throughout.
Problem is, once or twice a day, one or more of my computers, at different times, will display the message:
  • Another device on the network is using your computer's IP address
Unplugging the EX6100v2, although WiFi rage is reduced thereby, makes the problem stop.
A suggested hypothesis is that one or more devices occasionally will ask to renew a DHCP lease, or something, then the EX6100v2 will race the Arris NVG443B to serve the re-lease, causing a conflict.
I have plugged the EX6100v2 back in, and reconfigured it to use separate SSIDs.  The problem should recur within a day or so, if it is going to recur at all.
  • You can set devices with reserved or static ip addresses so that doesn't happen.
    Did you setup the extender using wps or using the installation assistant?
  • plemans's avatar
    • GilDawson's avatar
      GilDawson
      Tutor
      Thanks, plemans, for your quick response.
      I did set up the EX6100v2 using the assistant.
      Setting up with reserved or static IPs seems like a reasonable solution.  I had not thought of that.
      I suppose I should set up both the Arris cable modem/router and the EX6100v2 with the same reserved IP for each device, n'est pas?
      I'll have to learn how to do that.
      Thanks for the suggestion.
      --Gil
