Denno
Nov 03, 2015Aspirant
Antenna scheduling on WiFi extenders
Hi, I'm have a netgear router but I need a range extender. Now, I'm very interested in the wall AC plugin wifi extenders, but I feel I'm missing a feature. In my router I've setup the Wif...
- Nov 09, 2015
Hi Denno,
Yes, please see the following screenshot (in this example is the NETGEAR R6400 router):
For more on wireless scheduling:
Denno
Nov 06, 2015Aspirant
Ok thanks.
And would it be possie if I setup a netgear router in another place in my home as a wireless AP?
Will this AP then also function as an ethernet switch by the way?
- TheEtherNov 06, 2015Guru
Wireless AP is known as repeater mode on Netgear routers. Repeater mode is crippled on Netgear routers. There's no support for Wi-Fi security like WPA2, so I would not recommend using a Netgear router as a wireless AP.
On the other hand, you can use a Netgear router as a wired AP. That is, a second Netgear router can function as an AP so long as it's connected to the main router via Ethernet. It will also function as a switch.
Some Netgear routers also support what they call bridge mode. A router in bridge mode connects to the main router via Wi-Fi but any clients must be attached via Ethernet.
