SimonPieman
Aug 09, 2016Aspirant
Attempting to connect WG102 to Sky Hub SR102, and failing hard...
Hello all, I'm trying to provide internet access to my smart tv by plugging it into the WG102 via ethernet, which in turn would be connected by wifi to my Sky hub. I have never setup an AP befor...
DarrenM
Aug 12, 2016Sr. NETGEAR Moderator
Hello SimonPieman
You may want to check out the user manual on this help set up the product how you want it to work.
http://www.downloads.netgear.com/files/wg102_ref_manual_5_0_0.pdf
Darrenm
SimonPieman
Aug 12, 2016Aspirant
Hello DarrenM,
Thanks for getting back to me (and that is the politist version of RTFM I have ever seen).
That was my first port of call before switching the unit on, and has been the one thing I have referred back to but I am still confused...
It is probably obvious to other people on here, but not to me. I'll continue to plough on, and will post an answer if I manage to find it.
Simon
- SimonPiemanAug 14, 2016Aspirant
I gave up - a friend had a spare ethernet over power device and I just took the easy option.
This doesn't mean these two devices aren't compatible, but life can be too short to waste.
