Sebastiaan9
Feb 19, 2021Follower
Ax1800/Eax20 WiFi extender 5G problem
Hi, I have an R7000 router running fine for over a year now, no problems. I wanted to improve the WiFi in a sleeping room and decided to install an ax1800 (EAX 20 ) WiFi extender. The setup was done...
DexterJB
Mar 11, 2021NETGEAR Moderator
Hi Sebastiaan9, may we know if you are still encountering the issue?
- giulianogibiMar 22, 2021Aspirant
Did you find a solution? if so what was it?
I am interested to understand if it's possible to have the wifi scheduler working on both the base router unit and the wifi extender? if so, do I need two separate scheduling or is the extender schedule controller by the main router?
