edwin1993-_'s avatar
edwin1993-_
Blinking power
hi really need this help was working until i updated it then it started the power light to blink
  • StephenB's avatar
    Do you mean the status LED?
    Are you seeing the client WiFi network?  Normally a blinking status LED means the device has been reset, so the client network might be named NETGEAR_EXT.
      • StephenB's avatar
        I suspect the firmware needs to be re-flashed.  You might try sending DexterJB a private message (click on the envelope in the upper right of the forum pages), and ask if he can give you the procedure for that.
