bobnelms
Jul 03, 2015Aspirant
Brand new Samsung S6 Smartphone will not communicate with WN3000RP
I have 2 other devices, a notebook and another android that communicate just fine, but my brand new S6 will not hook up to the extender. I have reset the modem, the extender, and the phone itself. I ...
molineux1
Nov 07, 2015Aspirant
Hi, Ive judt provided a lengthy reply but it didnt post..
Basically ive just upgraded the firmware as you suggest and I have the sane problem.
I have the oldest netgear version
I can connect my galaxy tab, my iphone my galaxy s4 but not my s6. I have read on the internet that lots of other people have the same problem...
nhann
Nov 09, 2015NETGEAR Employee Retired
Hi molineux1,
Is your Samsung S6 able to connect to any network other than WN3000RP?
Check if there is a recent Android update for your S6
Please try the other solutions suggested in this thread, such as turning off the Smart Network Switch.
Also try removing your MicroSD card and rebooting your phone.
It does look like WiFi connectivity is a common issue with the Samsung S6. You may have better luck on Samsung S6 WiFi solutions by contacting or visiting their help forums
