bobnelms
Jul 03, 2015Aspirant
Brand new Samsung S6 Smartphone will not communicate with WN3000RP
I have 2 other devices, a notebook and another android that communicate just fine, but my brand new S6 will not hook up to the extender. I have reset the modem, the extender, and the phone itself. I ...
molineux1
Nov 09, 2015Aspirant
Hi, it will connect to BT openzones Wifi but wont download or send any data. It connects to the main BT home hub wireless in my house and downloads data quickly. Ive tried the smart switch option - it has no effect. The s6 doesnt have a microsd card.
Ill try the samsung site. Thanks Mark
skmtl
Dec 01, 2015Aspirant
Hi has anyone had any luck on this issue? Just got the S6 and have the same router WN3000RP and having the same issues?
- nhannDec 01, 2015NETGEAR Employee Retired
Hi skmtl,
Can you please confirm if you have tried any of the troubleshooting steps in this thread?
Are you able to connect any other devices to your WN3000RP? Can you please check your model version (v1,v2,v3) and if you are running latest firmware on the WN3000RP?
There is a common issue with the Galaxy S6 WiFi connectivity, Samsung may have an update on their official website.
