bobnelms
Jul 03, 2015Aspirant
Brand new Samsung S6 Smartphone will not communicate with WN3000RP
I have 2 other devices, a notebook and another android that communicate just fine, but my brand new S6 will not hook up to the extender. I have reset the modem, the extender, and the phone itself. I ...
Babylon5
Jul 09, 2015NETGEAR Employee Retired
A static IP will often help with connection issues, or at least reduce the symptoms to something easier to understand. So it seems that your phone is now associating with the network. The lack of Internet access could be for a number of reasons;
• The modem has no Internet connection
• The router is not communicating with the modem
• The extender is not communicating with the router
• The DNS server(s) are down / not communicating
Did you set the DNS addresses when you set the static IP?
Can you log into the extender and look at its status to check if it’s communicating with the router, and if so log into the router to see if it has an Internet connection?
