bobnelms
Jul 03, 2015Aspirant
Brand new Samsung S6 Smartphone will not communicate with WN3000RP
I have 2 other devices, a notebook and another android that communicate just fine, but my brand new S6 will not hook up to the extender. I have reset the modem, the extender, and the phone itself. I ...
Babylon5
Jul 12, 2015NETGEAR Employee Retired
bobnelms wrote: So here are my questions:
1. What static IP address should I be using? Should it be the address of the extender itself, i.e., 192.168.1.15? That's what I tried. Or do I simply make up an address?
2. What DNS 1 and DNS 2 address should I use? The example in the link used 8.8.8.8, and 8.8.4.4, so that's what I used. Is this right?
3. And what about the PROXY setting? I currently have it set to NONE. Is this right?
Thanks again
1. Use a high DHCP address e.g. 192.168.1.222, this is only intended as a test at the moment to identify the issue, but the address you used will definately not work.
2. use the suggested DNS
3. No proxy is needed.
Hans-Erik
Jul 28, 2015Aspirant
Hello!
I have exacly the same problem with my EX6200. It works fine with my laptop (Win 8.1), but not with my Galaxy Note 4, nor with Tab 10.1 2014 Ed. All devices communicate without problem directly with the router (Thomson TR789vn). Is there a solution for this problem??
