bobnelms
Jul 03, 2015Aspirant
Brand new Samsung S6 Smartphone will not communicate with WN3000RP
I have 2 other devices, a notebook and another android that communicate just fine, but my brand new S6 will not hook up to the extender. I have reset the modem, the extender, and the phone itself. I ...
Babylon5
Jul 12, 2015NETGEAR Employee Retired
bobnelms wrote: So here are my questions:
1. What static IP address should I be using? Should it be the address of the extender itself, i.e., 192.168.1.15? That's what I tried. Or do I simply make up an address?
2. What DNS 1 and DNS 2 address should I use? The example in the link used 8.8.8.8, and 8.8.4.4, so that's what I used. Is this right?
3. And what about the PROXY setting? I currently have it set to NONE. Is this right?
Thanks again
1. Use a high DHCP address e.g. 192.168.1.222, this is only intended as a test at the moment to identify the issue, but the address you used will definately not work.
2. use the suggested DNS
3. No proxy is needed.
brulain
Aug 24, 2015Aspirant
Hi,
I had exactly the same issue with a brand new Samsung GS6 : "Failed to obtain IP address". All my other devices work fine (MacBook, iPhone, Z2 tablet).
I changed WiFi settings on my SG6 : Static mode with IP address = 192.168.1.222. Now, my SG6 is connected to the WN3000RP (the signal is very strong), but not connected to the internet : all my connections fail (chrome, google play, ...)
Thanks for help.
