Retired_Member
Jan 27, 2016Can I connect a EX6200 Wireless Extender to existing router via Ethernet
Hi, I have recently upgraded to a Fibre UFB connection, and I must now use the Modem / Router provided by my ISP (It's a NetComm NF4V with modified firmware by the ISP). The router is OK (not...
- Retired_MemberJan 27, 2016
I think I just found the answer... in the EX6200 manual it says:
CAUTION: Do not use an Ethernet cable to connect the extender to a WiFi router. If you do so, the extender does not work because it is designed to use only a WiFi connection to a WiFi router.
So, it looks like the answer is "No".
Can anyone suggest a Netgear product that will work the way I need it to?
Thanks.
Retired_Member
Jan 27, 2016I think I just found the answer... in the EX6200 manual it says:
Thanks.
- netwrksFeb 04, 2016Master
According to the manual, you can use the D6300 as a Access Point - Page 99.
