Retired_Member's avatar
Retired_Member
Jan 27, 2016
Can I connect a EX6200 Wireless Extender to existing router via Ethernet
Hi,   I have recently upgraded to a Fibre UFB connection, and I must now use the Modem / Router provided by my ISP (It's a NetComm NF4V with modified firmware by the ISP).   The router is OK (not...
  • Retired_Member's avatar
    Retired_Member
    Jan 27, 2016
    I think I just found the answer... in the EX6200 manual it says:
    CAUTION: Do not use an Ethernet cable to connect the extender to a WiFi router. If you do so, the extender does not work because it is designed to use only a WiFi connection to a WiFi router.
    So, it looks like the answer is "No".
    Can anyone suggest a Netgear product that will work the way I need it to?
    Thanks.
