slyder2059
Oct 16, 2017Aspirant
Can I update firmware for EX2700 without using a laptop?
Hi there, I've had a EX2700 N300 Wifi Range Extender for some time and it's been working fine. It's situated upstairs in my room and the main router is downstairs in the living room. Suddenly my de...
DarrenM
Oct 18, 2017Sr. NETGEAR Moderator
If you can not access the gui of the extender over wireless then you would need a PC connected via Ethernet. You could try to power cycle the unit see if anything improves or move it to the same room as the router and see if you can access it then.
DarrenM
slyder2059
Oct 19, 2017Aspirant
Thank you for the reply.
I did a factory reset then switched off for a day. It's working now.
