5l
Jan 25, 2017Tutor
Can never get to www.mywifiext.net
I have just purchased this extender less than 2 weeks ago.It worked great up till 2 days ago.Now when my signal drops between 4 to 6 times a day.When I try to go to another netgear site it tells me I...
5l
Jan 25, 2017Tutor
Thank You,I did do all that several times.It does show me having a connection with 5 full bars with the wi-fi address my routers name and the _ext next to it.It also keeps connecting to my same wi-fi address without the _ext next to it and it does not matter if I uncheck the "connect automatically" box or not.I even have the genie installed and that shows a great signal.I just do not have a netgear modem but I have Timewarners.I,m just stumped.It actually works better with both connected.
TheEther
Jan 26, 2017Guru
What works better with both connected?
- 5lJan 26, 2017Tutor
I meant my wi-fi worked better with 2 signals from the same source with the same modem address.After reading your info i went ahead and reset the net gear extender one more time and started all over from scratch.it now works even better plus i moved it about 10 feet closer to the modem even though i had all green lights.And this time when I used the auto setup i also set up the modems addresse and my PC.Everything is now linked as one compete unit..Thank You for such a fast reply back yesterday.It really helped me out.
